Rebuild: need parts check and a few questions
Old Sep 18, 2013 | 09:54 AM
dapozer1's Avatar
dapozer1
Default Rebuild: need parts check and a few questions
I have my 04 5.7 apart due to number 3 and 7 piston failure. So at this point the cylinders and block have been checked and are in good standing. I have ordered a mater rebuild kit and plan on using all 8 pistons new, a new oil pump, new timing chain. I have also ordered a comp 260 cam, 6.1 exhaust springs and the 6.1 pushrods as well as a Jet 180 thermostat. Does this list sound about right? 6.1 pushrods will work with this cam, right?
Other questions:
-can I re-use the rod bolts or should I get new?
-can I re-use the head bolts or get new?
-Should I replace the water pump while I am at it? (75000 on engine)
-to seal oilpan back up should I use silicone?
I am sure I will have more, Looking at starting the rebuild on Friday.
Old Sep 18, 2013 | 11:57 AM
gcburkett's Avatar
gcburkett
I had my engine built this summer and a new water pump was pretty much required to get the 3 year warrantee. I don't know about the bolts but I think they tend to reused them.
Old Sep 18, 2013 | 12:36 PM
gcburkett's Avatar
gcburkett
In the service manual it states the connecting rod bolts are torque to yield bolts. Don't see any such notes for the head bolts
Old Sep 18, 2013 | 03:10 PM
TRO14's Avatar
TRO14
Rod bolts and main head bolts all need to be replaced. Secondary head bolts can be reused but I wouldn't reuse them for as cheap as they can be gotten.
Old Sep 18, 2013 | 10:16 PM
rtmtrrdr's Avatar
rtmtrrdr
You got the mater rebuild kit? Does it turn into a talking tow truck when your done?
Old Sep 19, 2013 | 08:56 AM
abarmby's Avatar
abarmby
Get a 6.1 oil pump while your at it. They're about the same price as a 5.7 but better in volume delivery I believe. It's a nice little upgrade for your new engine.
Al.
Old Sep 19, 2013 | 10:52 AM
Izero's Avatar
Izero
don't reuse any of the head bolts, or rod bolts.
I even suggest you get new valve cover bolts, as they tend to snap when you re-torque them....
