Vent control ac Defrost
Old Sep 22, 2013 | 09:50 PM
coolwind2003ab's Avatar
coolwind2003ab
Unhappy Vent control ac Defrost
Hello
I have a 1999 Dakota SLT 4x4
My controls will not swap from defrost to ac vents !
The line from brake booster across fire wall to passengers side and goes inside firewall this is the larger line & it has the tee close to center of firewall with what looks like a check valve this line is broken where does it go to ? Does anyone on here have pictures and info on this my cruise control works fine Please help as i cant afford to pay a dealer are a shop to repair it at this time
Thanks in advance
Greg
Old Sep 23, 2013 | 02:56 PM
66three83's Avatar
66three83
This is the third gen ram forum. However, you have a vacuum issue. your system works with vacuum, and if you lose it thru a broken fitting or anything else, your engine isn't going to run right and you will lose your a/c heater controls. Do a search on the appropriate forum and you have a better chance of finding a specific answer.
