drive axle u joint replacement
Old Oct 4, 2013 | 12:26 AM
beckman's Avatar
beckman
Default drive axle u joint replacement
hi guys i am having trouble removing the drive axle u-joints on a 2004 dodge 1 ton dually 4x4 i cant get the wheel bearing off to get to the axle u-joints any help would be greatly appreciated thank you
Old Oct 4, 2013 | 08:11 AM
gcburkett's Avatar
gcburkett
Did you try loosing the 4 bolts to the hub about 1/4 inch and using the socket and extension against the axle turning the steering wheel to push on the axle bolts.
Old Oct 4, 2013 | 07:48 PM
66three83's Avatar
66three83
It's probably going to take heat. Be careful using your power steering to pop it off. I tried that method and now my pump has a constant whine, plus, it didn't get it loose. If you live anywhere they use salt on the roads, you are going to need a torch and a small sledge.
Old Oct 6, 2013 | 02:51 PM
cyclone429's Avatar
cyclone429
Your going to have to use a press of some sort to push it off. Not so easy to do in a drive way. Rust builds up and seals the wheel hub. Add a new wheel hub to cost of the u joints and go with servicable units..
I went threw this on my 06 2500, I paid big bucks to have this work completed.
I have a pic in my garage of the basterd hub.
