OBD code C68
Old Oct 4, 2013 | 09:58 AM
andyb-1969's Avatar
andyb-1969
Smile OBD code C68
Hi , I posted this in the wrong area when i added myself to the map.
I`m Andy from England with a Ram 1500 , i had this code come up which is : Driver door unlock output circuit shorted to ground or voltage.
So i thought to start with i would check the fuse, doors are on the 20 amp fuse location 22 , the fuse looked ok but i changed it anyway and the engine light went off and has been ok. I will however keep an eye on this, i cant believe it could be that simple !
Cheers !
Old Oct 4, 2013 | 10:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Did your locks work during this code?
Old Oct 6, 2013 | 02:45 PM
andyb-1969's Avatar
andyb-1969
Default OBD code : C 68
Hi mate , yes all the doors worked as normal regardless of using the key fob or locking from inside. Strange one ? Been out in the truck quite a few times since with no problems.
Cheers.
