12v or GND lead triggered by hazzards.
Old 10-07-2013, 01:24 PM
jhebbel's Avatar
jhebbel
jhebbel is offline
I think ill "hack" a second set of contact points into the switch to run a standard 12v relay. There is plenty of room inside the MFS.
Old 10-08-2013, 09:33 AM
Izero's Avatar
Izero
Izero is offline
Did you measure how much current you had running through those contacts?
Enough to trigger the relay?
Old 10-08-2013, 09:37 AM
jhebbel's Avatar
jhebbel
jhebbel is offline
Doesn't matter, the hazards are triggered via the load being between certain ranges not by current. In theory pins 2 and 3 are always a closed circuit. I will have to create a separate circuit to trigger a traditional relay.
Old 10-08-2013, 02:59 PM
Izero's Avatar
Izero
Izero is offline
Very Creative way Dodge made that whole setup work.
I've got a few ideas in mind how I could work that circuit out... what a pain in the @$$ though..... lol
Should be interesting to see which way you pick.
Quick Reply: 12v or GND lead triggered by hazzards.
