used camshaft install advice/tips
Old Oct 9, 2013 | 12:22 AM
redram2007's Avatar
redram2007
Default used camshaft install advice/tips
I am planning on installing a set of used HO camshafts, they are in pretty good shape. No worn spots, rust, or any signs of damage/wear. What is the best products and method of cleaning the camshaft, and lubrication prior to install? Cam bearings, lash adjusters, etc? Is there a break in procedure for a different size camshaft? And anything else I failed to mention.....
Thanks
Old Oct 9, 2013 | 01:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Just spray them down good with carb cleaner. You can use cam break in lube for startup.
Old Oct 9, 2013 | 02:26 AM
redram2007's Avatar
redram2007
Thank you.
Old Oct 9, 2013 | 06:17 PM
redram2007's Avatar
redram2007
I may have a problem now, after cleaning the cams up I noticed that one of the lobes have a couple small scratches. They are not deep or long and appear to have happened when the guy I bought them from removed them. He is not what you would consider mechanically inclined and I insisted that I could remove them but he didn't want a stranger at his house. Anyways is there a rule of thumb on stuff like this? All lobes have the same wear pattern. I'm thinking about using some 1000 grit wet sandpaper and oil or kerosene to smooth it out. Any thoughts?
Old Oct 9, 2013 | 06:59 PM
p38251's Avatar
p38251
Give a call to your local machine shop. Those surfaces damage easy. 1000 grit may damage it worse.
Old Oct 9, 2013 | 08:38 PM
redram2007's Avatar
redram2007
I will give them a call but after a lot of digging most say it will be fine as long as you can't feel them or your fingernail doesn't catch any of the scratches. If I do have to have it machined or buffed then wouldn't that change the profile of the cam.
Old Oct 10, 2013 | 08:08 AM
p38251's Avatar
p38251
Machining yes buffing no.
Old Oct 10, 2013 | 09:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Usually an emery cloth is what you would use
Old Oct 10, 2013 | 11:00 AM
redram2007's Avatar
redram2007
Is their different grit of emery cloth,( I'm sure there is) if so what grit would be recommended? Thanks for the advice guys.
Old Oct 10, 2013 | 11:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There are different ones and your choice is going to depend on the scratch. Honestly, if you cant hit it with your fingernail, I wouldnt bother. This isnt a NASCAR engine
