Noise when braking
Old Oct 9, 2013 | 04:38 PM
wyomingchad's Avatar
wyomingchad
Default Noise when braking
My 2006 Dodge 2500 Mega Cab 5.9 has just developed a "thud" noise while braking. When braking and I get to about 20mph there is a thud noise I can hear but not sure where it is coming from. If I do not brake and coast to a stop I cannot hear the noise. It also does not happen everytime I brake only every two or three times. My truck just turned 90,000 miles as well.
Any ideas what is causing this?
Old Oct 9, 2013 | 06:52 PM
p38251's Avatar
p38251
Have you had brakes done? Loose caliper. Pad moving around. Check suspension components too. Shocks, balljoints swaybar links ect....
Old Oct 9, 2013 | 11:43 PM
Will_V2Lab's Avatar
Will_V2Lab
I've had thunks on other vehicles too. Definitely give everything a look over like p38251 said.
Old Oct 10, 2013 | 10:14 PM
eng18ine's Avatar
eng18ine
it could be a loose caliper like someone said. could also be worn pads. also check the rotors. but prety much anything that would move forward when under braking.
Old Oct 11, 2013 | 12:30 PM
wyomingchad
I am noticing that the clunk sound happens when braking right around 19 miles per hour and only does it when I get above 30 miles per hour before braking.
Old Oct 14, 2013 | 12:50 AM
Will_V2Lab's Avatar
Will_V2Lab
Have you checked things underneath? See if there's any play in suspension bushings or anything wrong with the brakes?
If it does it over 30mph it's got me thinking its suspension related...
