one side of 2wd front suspension is lower
Old Oct 29, 2013 | 07:34 PM
team_realtree's Avatar
team_realtree
Default one side of 2wd front suspension is lower
Measuring from top of tire to top of wheel well there is a 2" difference on the passenger side. It is quite noticeable and the only thing I can think of is a sagging coil spring? Shocks are new. The control arms on the higher side of the truck are on a steeper angle. It's almost as if one spring is longer? Can the springs be installed upside down? I also have 1.5" spring spacers
Old Oct 30, 2013 | 08:45 PM
team_realtree
Any ideas?
Old Oct 30, 2013 | 11:39 PM
gcburkett's Avatar
gcburkett
A broken spring might drop it that much.
Old Oct 31, 2013 | 10:13 PM
team_realtree
I took everything apart recently to change upper control arms I think I would have noticed a broken spring but maybe not. I'm gonna try switching the springs left to right to see if that is the problem.
Old Nov 1, 2013 | 10:22 AM
gcburkett's Avatar
gcburkett
Is there a difference between each circle of the springs the same or is the low side compressed more. There are some shocks that provide lift. If you have those then one shock could have failed.
