Cruise not working..
Old Nov 17, 2013 | 02:51 AM
ronixrider82's Avatar
ronixrider82
Default Cruise not working..
I have a 07 and not sure if it is like the older dodges or not. My cruise stopped working.. The light does not come on or anything. I tested the switch's and they are getting power. I just got it back from the shop they replaced my struts and did a front end alignment and now its not working. I looked for a fuse and couldn't find one. Any suggestions? I tried looking for the control module it self and couldn't find it.
Old Nov 17, 2013 | 07:29 AM
rought's Avatar
rought
the sensor is in the left front Wheel hub/bearing . check that
Old Nov 17, 2013 | 03:30 PM
kx250frider617's Avatar
kx250frider617
Mine hasn't been working either. I also replaced my front hubs with timkens, which replaced the ABS sensors and that still didn't fix it. I believe it the ECM that controls it. I pulled the main harness to do the Torque Management trick on the 03' hem's. Cruise control worked once after that but never again.
