slight clunky feel
Just two days ago on my 05 I heard a light clunking or chatter noise coming from the front,I think the right side.seems only when I turn to the left.
And really only at low speeds but not all the time, never does it going straight.what could it be? Wheel bearing, u joint? Cv,? Going to look closer tomorrow when I put the front on jack stands.maybe a broken brake pad but I doubt it. Doesn't pull.this sucks right around the holidays.
Hope u guys have some in put and have a great Thanksgiving holiday.
Shawn
Shawn
Check the u-joint for the T/C to the rear drive line first-----best to remove the drive line to do this, if it isn't moving smoothly--its time. Seems like that's the one that gets worn out first, but not always.
I saw your post after I pulled the front passenger side, don't know a little play when I grab the tire from top to bottom but I not much. Did it to the drivers side and didn't budge.don't know .being I have the wheel off should I look deeper into this? Also what size nut that holds the hub on? A lot of variables to look at.came inside to warm up, I'll check back here in a little to see any more inf before I go back outside.
I'm almost 99% sure its the right front.I put the tire back on for the hell of it and I wiggles a little and the drivers side nothing.it only grinds slightly on and off. Maybe not bad yet.if I pull the 1 11/16 hub nut off what do I have to do then? I'm somewhat mechanically inclined to try it.just don't know what to look for or if I have the proper tools
Trending Topics
what can I look for to see if this it?
