Which brand Water pump to go with?
Old Nov 30, 2013 | 01:09 PM
RamChiver's Avatar
RamChiver
Default Which brand Water pump to go with?
Need to replace my water pump...(again).. this time I plan on buying a quality part. also should I go to a lower temp thermostat. and I would also like to find a housing that isn't plastic...any suggestions. I"ve been looking at gates parts but haven't found any reviews
Old Nov 30, 2013 | 07:02 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would use Mopar parts. But the choice is up to you.
Old Nov 30, 2013 | 08:18 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I bought one from Advance Auto Parts not too long ago. Brand new. Not reman. I ordered it online and used a discount code I found off Google and saved quite a bit
Old Dec 1, 2013 | 11:31 AM
rought's Avatar
rought
you can order the thermostate here
http://www.highhorseperformance.com/...1L_p/10183.htm
Old Dec 1, 2013 | 11:40 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by rought
Of check this out for cheaper and equally as good alternatives
https://dodgeforum.com/forum/3rd-gen...at-part-s.html
Old Dec 2, 2013 | 01:37 PM
Rkymtnh's Avatar
Rkymtnh
My opinion as well. I'd definitely go with the one from Mopar.
I had two from Advance go bad.
