Please help diagnose leak (red fluid)
Old Dec 4, 2013 | 05:41 PM
flyinb501's Avatar
flyinb501
Default Please help diagnose leak (red fluid)
Hey Guys,
I noticed an oil leak on my driveway, and it seems to be getting worse. It is red fluid so I assume tranny or power steering. I have attached some pics. Does anybody have any idea where this could be coming from? Thanks in advance.
Old Dec 4, 2013 | 07:02 PM
chuck_hammer's Avatar
chuck_hammer
leak behind power steering pump.. maybe a hose...
Old Dec 4, 2013 | 07:40 PM
DirtyDodge812's Avatar
DirtyDodge812
Power steering fluid no doubt. Follow the hoses to find the source, if no luck there it might be a seal on the pump or tank.
Old Dec 4, 2013 | 08:15 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
That first pic looks like the 5 year coolant. The way it's trailing along the oil pan seam makes me think your water pump is leaking.
Old Dec 6, 2013 | 03:52 AM
abarmby's Avatar
abarmby
Dip your finger in the fluid and then taste your finger.....if it's coolant, it will taste unbearably sweet. Just try a tiny bit as it's nasty tasting, but tells you 100% it's coolant .
Al.
Old Dec 6, 2013 | 08:13 AM
flyinb501's Avatar
flyinb501
Thanks for the input guys. I just dropped it off at the shop last night. It's -5 degrees here, and I don't have a decent garage to work in right now.
Old Dec 6, 2013 | 07:03 PM
TNtech's Avatar
TNtech
Hory Cwap !!
Old Dec 6, 2013 | 11:28 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Coolant is my vote also. Time to change the water pump I'm willing to bet
Old Dec 7, 2013 | 12:42 PM
flyinb501's Avatar
flyinb501
It was the coolant. They said the thermostat needed to be replaced. Thanks guys!
Old Dec 10, 2013 | 07:56 PM
Adambomber's Avatar
Adambomber
You have red coolant?
