3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Get guys. I have a ticking sound coming from my truck sounds like it's in the area of the ac compressor. Is it a common problem on them? It has 120000 miles. Hoping that's all it is
Does it make any difference if you turn of the AC?
Is it a loud ticking or more like a relay kind of ticking (Thinking of the sound from the injectors)
My AC compressor is actually knocking. It's probably not long for life. Aside from that, the engine does have a tick. I'm led to believe it's either the timing chain tensioner or a wrist pin out of tolerance. Either way, It's been 16,000 miles and I haven't had a single issue since I bought the truck.
Water pump is about to go out. I had a noise and someone said it was a pulley, I didn't know what it was, and the first cold day my truck started making a crazy loud squeezing noise and then the ticking noise quit altogether. I then drove to the bank amd my truck started overheating. The impeller on my waterpump had cracked and was not turning with the shaft. So if I was you I would take off the water pump and check the impeller ( round plastic thing that tuns the water)
