HELP! Front Brakes grinding/scrapping sound While Braking
2002 Ram 1500, 4.7, 2-WD
when braking at low speeds my front brakes sound and feel like they are scrapping..feels like ABS kicking in, roads are dry.
I just replaced my pads with ceramic pads, and new rotors.
Any suggestions??
Your help is apprecaited.
Roger
Any suggestions??
Roger
Not true! The seal on the caliper piston is a rolling rubber seal. When you release the pedal the rolled seal helps to pull the piston back away from the rotor.
