Radio Power Without Key
Old Dec 21, 2013 | 11:20 AM
AKCallahan's Avatar
AKCallahan
Originally Posted by Izero
Check your owners manual.... As far as I remember nearly all of the newer Dodge trucks I've ever installed radios on with a Databus would stay on once turned off, and would stay on until a door was opened.
Confirmed?
Old Dec 21, 2013 | 12:30 PM
66three83's Avatar
66three83
No. Not by me.
Old Dec 22, 2013 | 09:28 AM
dirtydog's Avatar
dirtydog
Moderate User
I have a 2008 with an aftermarket radio. I also have my own harness that is NOT a canbus overpriced/convenient plug'n'play! My radio stays on when the truck is off until 10min timeout or until I open up the driver door!
I used the cigar outlet which is fused on a timer. Whoever put the radio in, must have used direct ignition power not on a timer. All OP needs to do is switch the power lead to a diff wire.
Old Dec 22, 2013 | 11:07 AM
dakotatrevor's Avatar
dakotatrevor
My 06, factory radio is off with the key.
Edit - It very well could be a setting I'm not aware of, but a quick search of my owners manual didn't come up with anything. I think chrysler calls it "retained accessory power"
Old Dec 23, 2013 | 07:18 AM
Izero's Avatar
Izero
That's the secret way to install without the CANBUS Adapter... lol
It also sucks b/c if you have something plugged in that draws a bit more power than say a cell phone charger you'll pop the fuse in a heartbeat, but it's a low-tech means to save yourself $60-$100 on install parts :-P
Old Dec 24, 2013 | 11:04 PM
Old man with a Hemi2's Avatar
Originally Posted by 66three83
Anyone else with a 2006 want to chime in? Does your stock radio stay powered up after ignition is turned off? Because ONCE AGAIN, my stock 2006 DOES NOT!!!
My 2006 radio also turns off as soon as soon as the ignition is turned off. The same since it was brand new
