Loosing Oil Pressure when at a stop
I have a 2004 Dodge Ram 1500, 4.6L V8 (289). When the engine is warmed up and I come to a full stop the "check gauges" light comes on and the oil pressure drops to zero. If I rev up the motor it goes up again only to drop again if I do not hold the revs up. I searched lightly yesterday on the possibilities and came up with replacing the oil pickup (where is this on my truck?), or replace the plenum http://www.****************.com/smf/...p?topic=9504.0
Any input of what this might be or where I should start in my diagnosis would be greatly appreciated. Thanks guys!
How can I check the switch? Pull out the instrument cluster and use a multimeter?
no. there is a electric sensor on the engine...
since the gauge in the dash moves .. it is most likely Good.
the sensor is fairly cheap.. I would just replace it..
or take it to a Shop and have them test the system.. or temporality hook up a mechanical Gage to read oil pressure.
I'm going to replace the sensor since its a very cheap part. My buddy is coming over this weekend and will hook up a mechanical gauge to read the oil pressure. I'll double check the oil level just to eliminate the simple stuff. Thanks guys, love the support for fellow DIY's.
Hey bud. Haven't seen you in a while and certainly not up this way.
I agree with changing that oil pressure sensor first. Remember it gets grounded in the block so make sure the threads are clean.
sure you got a 4.6L in it? Isn't that a Furd engine? You ain't go no Frakendodge do you? LOL
Trending Topics
