shock replacement!!
Old Jan 3, 2014 | 03:59 PM
tecinc04's Avatar
tecinc04
Default shock replacement!!
can you replace rear shocks with coil overs on a 2002 ram 2500 with leaf springs
Old Jan 3, 2014 | 05:28 PM
Gone Fishin's Avatar
Gone Fishin
Ummmm yah, shouldn't be a problem, just make sure the manufacturer has designed them for your truck.
Old Jan 3, 2014 | 06:48 PM
MikeHTally's Avatar
MikeHTally
Guess they'll work like booster springs. Might stiffen the ride too much.
Old Jan 4, 2014 | 02:33 PM
tecinc04's Avatar
tecinc04
Thanks Guys for the input.
Old Jan 12, 2014 | 08:23 AM
spuldup's Avatar
spuldup
I put monroe coilovers on my 1500 about 6 months ago. It does stiffen the ride, which is to my liking. Also adds some "unofficial" payload capacity and the bed does not sag with only a few hundred pounds in it anymore. Plus, a pair is only like $90. I would recommend them.
They also raise the rear end about 1-1.5" which will add to your rake if not leveled. I have bilstein 5100s up front at the max setting and the truck still sits with a slight (~1.5") rake. I had the coilovers in with stock front shocks for a few weeks and it looked a bit odd (~4" rake).
