No heat on the floor
Old Jan 5, 2014 | 10:54 PM
cupcake65's Avatar
cupcake65
Default No heat on the floor
2006 dodge ram 1500
The heat works on everything except the floor , feet are freezing the air bag gets very cold ..Also very cold when the heat is not on the floor , passanger more then the drivers side
How can i fix this ??? thanks
Old Jan 6, 2014 | 04:21 AM
abarmby's Avatar
abarmby
Do a search either on here or google, for Heater Treaters.
They have videos on hiw ti diagnose HVAC faults and the goatees needed to repair those issues.
Sounds like you have a "mode door" fault.
Al.
Old Jan 6, 2014 | 08:14 AM
Izero's Avatar
Izero
My truck just started having this issue but to explain further:
Whenever I set the controls to Upper vents & Feet, Feet, or Feet + Defrost it will almost 100% come out of the defroster vents on the top of the dash instead of the feet.
Also if I set it to Feet or Feet & Defrost setting and the heat is set to anything above 3/4 of the way to "hot" it feels like the heat is set to 100% come out of the defrost vents. So basically the heat melts my eyeballs and if I set it any lower it just comes out cold....
The heat is extremely strong so it's definitely not a heater core issue, so I'm leaning towards it being a blend door problem, but I haven't had the time to get my snake camera out and start troubleshooting the issue.
If it is the blend door I'll prolly just leave it alone unless it's just a problem with something that doesn't require a complete removal of the interior....
Old Jan 6, 2014 | 10:34 AM
66three83's Avatar
66three83
You can access this door. It is located to the right of the gas pedal. Take a light and a long screwdriver, and you can flip the door to the opposite of where it is now. This will give you control over floor and dash vents. If you switch your **** back to defrost, it will get stuck there again. I have been living with this for over a year, and it is an easy go around.
Old Jan 6, 2014 | 12:50 PM
Izero's Avatar
Izero
That is very good to know!
Old Jan 6, 2014 | 12:58 PM
Daves69's Avatar
Daves69
Careful how hard you push. You don't want to be breaking that hi-speed plastic!
