545rfe swap, need programming?
Old Jan 7, 2014 | 10:23 AM
bomrat's Avatar
bomrat
Default 545rfe swap, need programming?
hi, i am swapping my 545rfe to another one, my 4th and 5th gear was burnt out due to a line failure.
the guy at the salvage yard said i need to have the ecm reprogrammed for the new transmission. is this true and how do i do this or get this done.
thanks
Old Jan 7, 2014 | 10:25 AM
Izero's Avatar
Izero
thanks
PCM* and no as long as it is from a similar year as yours you will be fine...
2002-2005
2006-2009
2010+
Old Jan 9, 2014 | 12:09 PM
bomrat's Avatar
bomrat
whats the best way to find the date on the 545rfe...
Old Jan 9, 2014 | 12:37 PM
Izero's Avatar
Izero
serial number and contact Dodge directly...
Or if there happens to be a VIN number stamped or stickered onto it....
Old Jan 9, 2014 | 01:04 PM
HemiLonestar's Avatar
HemiLonestar
You WILL need a quicklearn perfromed though, as your current PCM will have CVI values from your previous transmission. This will require a dealership style computer, so if you know someone with one or you will have to take it to a dealer.
