Replace Airfilter for second Battery
Old Jan 11, 2014 | 12:51 PM
dirtydog's Avatar
dirtydog
Moderate User
Both Airraid and S&B sell filters that dont require oil.
The oiled one's only require oil every 40-50kmi anyways.
Old Jan 11, 2014 | 12:57 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah. Dirty found my S&B for me. Last week when I changed out my water pump I cleaned it out. Sprayed it with Purple Power and rinsed it out. Then gently blew it out with air (to get most of the water out) and let it air dry
Old Jan 12, 2014 | 12:26 PM
Rik's Avatar
Rik
me is not about the "work" that is not a problem! I thought that the oil filters must be frequently / oiled regularly ...
If the need "just" happen all 40kmi, that would be no problem.
Have the oiled air filter advantages over the non-oiled
Old Jan 12, 2014 | 02:58 PM
chuck_hammer's Avatar
chuck_hammer
yes. 30,000 mile .. check manual.. I do once a year .. just because I have 4 to maintain. I do all 4 on the same day.
doing it for 30 years...
first.. you can wash and re-oil over and over.. for many years.. NO REPLACEMENT...
might give you slightly better gas mileage.
proven to provide more air to engine (if needed).
and with many stock air filters now over 15 dollars each.. I am saving money.
Old Jan 12, 2014 | 03:19 PM
tantofolder's Avatar
tantofolder
Rik,
Here is the information on cleaning from K&N:
http://www.knfilters.com/cleaning.htm
Old Mar 8, 2014 | 11:03 AM
Rik's Avatar
Rik
hi!
from a friend i get an Vararam-Aircleaner. To install them, i have to replace me the cooling-water-reservoir.
I have a question therefor, here you can find it: https://dodgeforum.com/forum/3rd-gen...voir-tank.html
thanks a lot!!
