Key wont turn
Old Jan 11, 2014 | 02:43 PM
redrumrevolution1's Avatar
redrumrevolution1
Default Key wont turn
Someone attempted to still my truck and screwed up my ignition. I have a 04 Ram Hemi. The steering wheel is locked also. I tried moving the steering wheel and wiggling the key but no turn. I need to change the ignition cylinder out. How do you remove the ignition cylinder without turning the key.
Old Jan 11, 2014 | 02:59 PM
dirtydog's Avatar
dirtydog
Moderate User
Have you removed the pplastic shroud that covers the steering wheel base? Make sure the electronics are still plugged in.
You may have to remove a bit more to gain access to the locking mech so you can do it manually.
Old Jan 11, 2014 | 03:06 PM
redrumrevolution1
Yes, the plastic is moved
Old Jan 11, 2014 | 03:11 PM
redrumrevolution1
Everything is still plugged up also
Old Jan 11, 2014 | 09:38 PM
p38251's Avatar
p38251
Try giving the wheel a pretty good tug, while trying to turn the key. Did they stick something into the ignition cylinder? If so I would just replace it.
