cv boot leak
my front cv boots booth are leaking a small amount but last night I noticed one has turned into a big leak about a foot long by about 4 inches wide.can I ride this way for a while until I save up the money to replace it?what type of fluid is that ,that its leaking anyway?just wondering how soon I should get on it and have it fixed since the leak just got worse yesterday.
The CV boots hold grease so I think you you have a rack and pinion leak. OR something leaking onto you axles. If your CV boots tore, it would throw green grease all over your wheel wells. I would check your power steering fluid and keep it topped off until you can fix it.
Yep, CV is packed with a green grease, very thick. I've got an inner boot that let go and have a good bit of slime under the truck. All my rubber (boots) are shot due to my fishing a good bit of intercoastal waters.
I've got a pair of Cardone CVs, lower ball joints and upper control arms sitting in the garage. Just need to heal up a bit more from recent surgery before tackling the replacement...
Can you post pics of your outer boots installed on your truck when you are finished. I had a problem where the boot had a larger diameter than factory and would rub against the lower control arm when the suspension drooped down. I since, lowered the front of my truck to 1" lower than the rear. It used to be and inch higher with the torsions cranked.
Hopefully whatever is failing doesn't cause you to have an accident!
