Intermittent SERV 4WD light - Any Thoughts???
I have a 2008 Ram 1500 Laramie with 95K miles. I have been using the 4WD since early to mid December '13. A few days ago the SERV 4WD light has been coming on intermittently. The light/alarm comes on and clears immediately. Sometimes it comes on when I am at a standstill and some times when I am driving. I am pretty sure the 4WD is working. The light only seems to come on during the first 10-20 minutes of driving. I am planning to take it in but was just wondering if there was anything I could check before I do.
Any thoughts?
Any thoughts?
This topic was up a month ago..
I copyed and post this link Dirtydog had on his post..maybe it will help..
https://dodgeforum.com/forum/3rd-gen...4x4-light.html
It could be a cold weather related issue, or it might be time for a transmission fluid change along with the transmission filters...
Any thoughts?
Any thoughts?
The shop checked out everything and found a short in the selector switch inside the cab. Switch is on order and should be installed later this week. I will let you know if this indeed fixes the problem.
