Dome light stuck on...help?
If its anything like my 01 dakota. its the headlight/dimmer switch. I have to dim the dash lights a bit, and the dome light will go off.
You know how there 3 clicks and than the dimmer. top click is cargo light, next is dome, than dome set to door trigger, put the setting on the dimmer only. and see if that helps. of course you will have to click the switch up at night when opening the door. or replace the switch..
Hope this helps
Hope this helps
