front drive shaft problem
Old Feb 15, 2014 | 03:03 PM
Jongroehler25's Avatar
Jongroehler25
Default front drive shaft problem
I have a 2004 dodge ram 1500 awd/4wd. I was hearing a loud grinding noise from underneath the truck so I check the front drive shaft and the prop cv joint was bad so I replaced it and it fixed the grinding problem. during that same day after the new one was on not even 20 min later I started hearing the gringing noise again so I checked the shaft again and the prop cv joint was smoking. I need help please
Old Feb 15, 2014 | 03:41 PM
Going to move this to the third gen ram section for ya.
Welcome to DF!
