Rear end noise
Old 02-24-2014 | 02:53 PM
KWick's Avatar
KWick
Default Rear end noise
2005 2500 / HEMI / 4WD / QUADCAB
I have been to numerous shops and nobody can ID the problem, as it rarely happens.
What happens is, when driving a long distance, 25 miles or further, or when towing a trailer, I get off the exit and it has a spline noise. It happens on the first acceleration, but goes away after that unless I drive longer than 25 miles. It happens always when I tow a trailer, and rarely when do not. I do not want to rip apart the rear-end if someone has had the issue, or turns out to be the drive shat etc.
anybody had this issue?? What was the fix if you did.
Kevin
Old 02-25-2014 | 02:25 AM
44dakota's Avatar
44dakota
sounds like you should jack the rear end off the ground,get under the truck and see if you have any up&down movement in the pinion,or play in the u joints and if the driveshaft has a splined slider(not sure) id check that also for up and down movement,those are the 3 simple checks you can do,if those check good then its probably coming from inside the rearend or transfer case itself..
Quick Reply: Rear end noise
