What should I be looking for in rear lift block kits?
Old Feb 26, 2014 | 02:41 PM
Ram 02's Avatar
Ram 02
Default What should I be looking for in rear lift block kits?
I'm needing to lift the back of my truck up and when looking for blocks I found that a 2" lift block can range from $50 to $150. Is there any particular reason why. What should I be looking for or staying away from in lift blocks? Thanks
Old Feb 27, 2014 | 12:21 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I had blocks from Autozone on mine at one time. You can also use lift shackles though
Old Feb 27, 2014 | 01:09 AM
Ram 02's Avatar
Ram 02
I need to raise the rear of my truck up between 2" to 2.5". So should I look for a 2" lift shackle if I want to raise it the 2" and is that all I'll need is just the shackle? Can you provide a name or a link to a company that sells them, I'd appreciate it. My trucks a 02" 1500 2wd
Old Feb 27, 2014 | 12:09 PM
HammerZ71's Avatar
HammerZ71
I've got a set blocks that came with my Rancho lift kit been on the back of mine for over seven years now with a good bit of towing and off-road use. No issues. Have installed a few sets of blocks from Autozone on a few trucks as well and have never had a problem with them either...
Old Feb 28, 2014 | 11:49 AM
Dubl0Vert's Avatar
Dubl0Vert
Did you need longer u bolts?
