3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
My 2006 2500 has an intermittent problem with the e-brake light coming on at different times. The brake is not engaged so I am asking for solutions. Is it the switch at the pedal or is it a programming thing?
I had a switch problem with mine, bumped it will adding an extra fuse block.....it fluttered for a week till i bent it back.....also lubed the cables just to be safe
