PCM programming
Does anyone know of any company out there that takes the stock PCM from an '03 5.7 and can re-program the PCM for mods that have been done? Also doing changes including timing, air fuel, power enrichment, speed/rev limiters, shift points, shift firmness, torque management?
Thanks
Thanks
No ****! If you knew anything about an '03 you'd know there isn't **** out there for them. That's why I was asking this alternative. There's a jackass on every forum.
Don't go off half-cocked without all the facts. 03's CAN be custom tuned with a DSP; it just isn't capable of all the adjustments that can be done on later years (and DSP's tend to fry 03 ABS modules and/or PCM's sometimes). You won't get the most out of your mods. B&G/Arrington can flash your ECM, however you have to send it in, then wait for it to come back. Not really an option if it is your DD or work vehicle.
