Whining Noise in front end when accelerating
Old Mar 11, 2014 | 11:48 PM
zack293's Avatar
zack293
Default Whining Noise in front end when accelerating
2004 dodge ram 1500 5.7L Hemi
When i accelerate i hear a whining/squealing sound somewhere in the front end but goes away once i am up to 40mph. I took a walk around while it was idling and i could hear it loudest from front right side of the truck. What also might help is that i noticed the sound after driving over a pretty nasty pothole
Thanks in advance for any help
Old Mar 11, 2014 | 11:50 PM
zack293's Avatar
zack293
also the squeal gets louder when I am making a turn
Old Mar 12, 2014 | 12:43 AM
benjamin78's Avatar
benjamin78
Power steering pump. Check the fluid first
Old Mar 12, 2014 | 08:54 AM
Izero's Avatar
Izero
Power Steering fluid is probably low, it happens.
Old Mar 13, 2014 | 01:39 PM
DodgeCACares's Avatar
DodgeCACares
zack293,
I'm sorry to hear about the noise issue you're experiencing. As @benjamin78 has stated, an issue may be present with your power steering. In regards a squeal noise, the source may be related to the pump, pulley or the power steering drive belt.
Pinpointing the direct cause may require further investigation from a servicing facility. I would hate to see you replace parts unnecessarily.
Keep us posted if you can,
Old Mar 13, 2014 | 04:32 PM
p38251's Avatar
p38251
Alternator bearing
