Stock Height
Old Mar 18, 2014 | 10:48 PM
SquirmyPug's Avatar
SquirmyPug
Default Stock Height
Anyone know the stock height for the front end of a 2002 1500 4X4 crew cab?(center of wheel to fender or some other way to measure)
I want to level it a little, but I want to set it at stock height first. It looks like the suspension has sagged a little, that's why I want to know the stock height.
The truck only has 42,000 miles on it, the upper ball joints are bad enough that the top of the tire moves almost 1/2" when I shake it. I'm going to replace upper and lower BJs and inner and outer tie rod ends, want to set the height while I'm fixing it so I can get an alignment.
With the BJs and TREs I also bought leveling torsion keys, should I even use them or just level by cranking with the stock torsion keys? Thanks for any info
Old Mar 20, 2014 | 05:43 PM
SquirmyPug's Avatar
SquirmyPug
Anyone able to help?
Also have another question, which ball joint press kit works best for these trucks? Thanks.
