3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I swapped motors from a 03 Durango into my o2 dodge ram 1500 4.7. the motor fires but will not crank. I have read that I may need to swap flywheels from one motor to the other because one is a 16 tooth and the other 32teeth. I also read that the cam and crank toner rings can be changed. Any help to get my truck stared would be appreciated.
The motor fires but will not start and run. I just found out that the motor has to come back out and the toner rings must be swapped out which in tails removing the crank.
Did you change the computers/controllers? Having just done a similar swap, I can tell you it is a serious PITA all the things you have to change out to keep from throwing codes.
