Fuel system cleaning
Old Mar 29, 2014 | 07:10 PM
Steves2008hemi's Avatar
Steves2008hemi
Default Fuel system cleaning
Hey all. Looking for some advise please.
Had my 2008 5.7 to an oil change place the other day. (It has about 128,000 Kms) They recommended a fuel system cleaning. Consisted of pouring stuff in the tank, and something into the engine then rev and all black crap will be blown out. This was $110.00 service.
I have seen bottles of injector cleaners at the auto store that are reasonably priced at about $14.00.
I am not even sure if it needs it as it runs fine. Any suggestions? Thoughts? Preferences? These oil change places can be known for the 'upswell'
Thanx!
Old Mar 29, 2014 | 07:32 PM
ALW1's Avatar
ALW1
I know there is one procedure where they hang a small pressurized bottle under the hood and plumb it into your fuel system in such a way that your engine runs off that only until the bottle empties and the engine stalls. Then they reattach your fuel lines and your injectors are supposed to be cleaned.
If you run regular fuel it probably couldn't hurt. If you use premium then it may not be necessary.
No way to really know until after
Old Mar 29, 2014 | 08:17 PM
Steves2008hemi
Thanx for that ALW1. I am all about regular maintenance. I always use the mid grade per the manual. This procedure sounds interesting though.
Old Mar 29, 2014 | 09:54 PM
ewing111's Avatar
ewing111
i bet you can get similar results with seafoam or marvel mystery oil, do a search there are several threads on both. Cost you around 20-30 bucks instead of 110.
Old Mar 30, 2014 | 10:39 AM
MikeHTally's Avatar
MikeHTally
Two bottles of Sea Foam will accomplish 'bout the same thing for $15 or so. I do mine once a year or so.
Old Mar 30, 2014 | 01:13 PM
PRF66's Avatar
PRF66
I paid to have the injectors cleaned on mine. The truck ran great after the servcie was performed. 92,000 miles. I don't know about Seafoam, I always learn the cheaper ways afterwards. Baring all the nonsense about trans service, differential service, transfer case service, brakes, brake fluid flushes, and a myraid of others DIY in MY DRIVEWAY ??????????? I THINK NOT !!!!!!!! That sounds like a cheaper service. Man these trucks are expensive to maintain. Thousands have said so.
They are good trucks, but expensive to maintain properly.
Old Mar 30, 2014 | 01:37 PM
ALW1's Avatar
ALW1
Lots of guys swear by this seafoam. How do you use it? Just a bit in the oil and in the fuel? I've also heard some guys will add some directly to the intake through a vacuum line?
Anybody have any negative results? I'm always a bit suspicious of anything that claims to be a cure all.
Given the internal PVC systems on these trucks and the way the gunk builds up in the intakes it would be nice to clean that out
Old Mar 30, 2014 | 02:55 PM
Blacksport's Avatar
Blacksport
Expensive to maintain? How do you figure? These trucks don't need any more maintainence than any other vehicles!
Old Mar 30, 2014 | 05:26 PM
MikeHTally's Avatar
MikeHTally
I agree. Maintenance on mine has been easy (too easy to pay someone else to do).
Old Mar 30, 2014 | 05:32 PM
MikeHTally's Avatar
MikeHTally
Full directions on the can, but a full can in the tank, then fill it up. Let it inhale 1/3 of a can through the brake booster vacuum line (warm engine), then let it sit five minutes or so, then start it up. If it's been a long time, you'll get a sizable smoke show. This helped the idle and throttle response on mine.
As for the oil, some say you can leave it in the crankcase all the time. I put in five ounces or so and then drive it a day or two before changing.
The PVC valve isn't internal - it's on the passenger side between the throttle body and the firewall. I clean mine at every oil change. As long as the check-ball moves, I'm happy.
