3rd gen shut off problems.
Old May 8, 2014 | 01:04 PM
jetman150's Avatar
jetman150
im trying to think this through a bit.. as far as logical scenarios that could replicate the symptom..
im guessing, that since there are 2 check valves on the tank, and a ball in the filler neck, that the chances of them all three causing a closed system vacuum , that might keep the fuel pump from pushing out fuel, that seems like more of a statistical oddity.
i do agree with the evap canister recieving gas, but wouldnt you see signs of that from the purge solenoid malfunctioning and throwing a check engine light?
especially since the evap canister is positioned well below the top of the gask tank?
I had the thought of replacing the evap canister, just for grins, but my deal is, how much money do i throw at this problem, without knowing the full extent of the problem?
It seems to me that the frequency of occurence, with other owners/vehicles, is quite a bit..
Old May 9, 2014 | 11:33 AM
dirtydog's Avatar
dirtydog
Moderate User
This issue has been discussed numerous times...
Guys fill up, and their truck dies when going around a turn.
Check valve is the problem with shutting off apparently.
Old May 9, 2014 | 08:24 PM
HammerZ71's Avatar
HammerZ71
Usually I see this being the issue when someone allows the truck to run out of gas. I think it loses prime. I know for a fact if you install a new fuel pump and don't prime it you experience the same issue. I've been told by more than one Mopar tech that runing out of fuel to the point of a stall does irreparable damage to the fuel pump and it will periodically stall until the pump is replaced.
Old May 10, 2014 | 10:17 AM
dirtydog's Avatar
dirtydog
Moderate User
Yeah, running fuel too low burns up the pump. Fuel is the cooling agent for a fuel pump.
I tell my wife all the time to stop running the fuel so low. been telling her for 9yrs. She keeps saying. I know. I know but nothing ever changes.
Generally fuel pumps die when you park a perfectly running vehicle, let it cool for maybe 10min or so and then try to start it again. Sometimes it happens at the pump..lol
