what brakes do i have 2 or 4 wheel ABS
Just 'cause you have ABS doesn't mean you have four-wheel ABS. Two-wheel is required, four-wheel is optional. It might be that if the rear brakes are disk, you have it, but that may not be true.
Find a patch of wet grass, sand or gravel and nail the brakes. If the fronts lock up, you have two-wheel.
My '03 has "disk" brakes in the rear and only 2 wheel ABS. My disks brakes also have a drum brake for the parking. That's not a reliable test. Just look at the wheel hub and see if you have a wire coming off or not. If you have a wire coming out of it, then it's 4 wheel ABS. If you don't have a wire, then it's 2 Wheel ABS.
It matters in that you need the right part. It might be possible to use a 4 wheel ABS hub in a 2 wheel system, but not the other way around.
You can also look up your VIN and get a build sheet. It should say something on there about the ABS.
http://www.dodge.com/webselfservice/dodge/index.html
Trending Topics
