Another Dodge steering Pop
Old May 10, 2014 | 03:11 PM
Bruecnkt's Avatar
Bruecnkt
Default Another Dodge steering Pop
Back Story on my Dodge:
2002 Ram 1500 SLT 4.7L V8 Love it to death
Problem: I have a steering pop/snap when turning both directions.
Recent work I've Done: Both CV Joints have been replaced and are in good condition. Both Hub assemblies have been replaced and are good all ball joints and tire rod ends are brand new as well, the rack and pinion has also just been replaced.
I have no clue what is causing the noise but it is killing me to hear it.
Any help would be greatly appreciated.
Old May 11, 2014 | 07:54 AM
big guy's Avatar
big guy
A long shot. Check to make sure the steering rack is torqued to spec.
Good Luck.
Old May 11, 2014 | 09:10 AM
chuck_hammer's Avatar
chuck_hammer
when you had the rack out.. did you check the bushing in the steering shaft for the steering column .. and is it put back in the Center position?
Old May 11, 2014 | 09:42 AM
brickjaw's Avatar
brickjaw
Sway bar bushings?
Old May 11, 2014 | 10:04 AM
Bruecnkt's Avatar
Bruecnkt
Everything is in and torqued right I will check the bushings on the steering shaft out thanks
Old May 11, 2014 | 08:10 PM
89gtcs's Avatar
89gtcs
x2 on sway bar or end links. Do you feel the pop in the steering wheel or just hear it?
Old May 11, 2014 | 09:54 PM
Bruecnkt's Avatar
Bruecnkt
I just hear it
Old May 11, 2014 | 10:04 PM
brickjaw's Avatar
brickjaw
Yeah def check those end links.They can make quite a racket. The bushings may be bad as well, they might look ok but that doesn't mean they're not shot.
