radiator coming apart. ......
Old May 11, 2014 | 04:18 PM
fsr2007's Avatar
fsr2007
Default radiator coming apart. ......
I have a 2007, 1500 with a small coolant leak. It was difficult to find but it looks like it's coming from the radiator. Upon further inspection it looks like the radiator is coming apart at the top and bottom. There are what looks like "relief" cuts in the top and bottom channels of the radiator. At those points the radiator is separating. Does anyone have any experience with this?
Thanks
Old May 11, 2014 | 04:22 PM
chris65's Avatar
chris65
What does it matter? If the radiator leaks, you have to replace it. If it's a 4.7 you better don't try anything-they are very sensitive to high temperature and overheating.
Old May 11, 2014 | 08:06 PM
Davedacarpainter's Avatar
Davedacarpainter
I had the same problem, no fix for it, replace and be happy.
Old May 11, 2014 | 08:50 PM
Convincer253's Avatar
Convincer253
I chased a small coolant leak on my 2007 1500 and ended up being the same thing...had to replace the radiator
Old May 11, 2014 | 10:08 PM
brickjaw's Avatar
brickjaw
Ditto. If it's the 4.7 don't risk an overheat. The heads can warp just from higher temps, doesn't even hafta be a full blown overheat condition.
Old May 12, 2014 | 08:19 AM
Convincer253
mine wasn't the 4.7 but the 5.7 hemi....but still the same ...had to replace
Old Jun 13, 2014 | 04:42 PM
NJSquatch's Avatar
NJSquatch
have a 2008 hemi had the same thing happen at 65K
Old Jun 28, 2014 | 09:00 AM
carl550k's Avatar
carl550k
mine did the same. on top. 08 hemi..new one on the way
