is my truck haunted?
Old May 12, 2014 | 01:03 PM
Jim W.'s Avatar
Jim W.
Default is my truck haunted?
Sometimes when i first start the truck it runs rough and rich. It has plunty of power and runs fine down the road. At the traffic lights its just a little rough but doesnt act as bad. Sometimes i will get a CEL for a few days. The CEL says p300 and sometimes p410 i think. I had the plugs, wires and gas cap changed. It helped some but not completely. I also have a clicking noise in the dash by the glove box, i think it might be the fresh air door in the a/c heating. But it's only clicking between 40 and 65 mph.
Old May 12, 2014 | 03:58 PM
chris65's Avatar
chris65
yes- your truck is haunted...
with the information is not much to say about.
Old May 12, 2014 | 05:50 PM
Jim W.'s Avatar
Jim W.
Default thought so
This help? 2004 1500 5.7 122k 4x2
Old May 12, 2014 | 09:29 PM
p38251's Avatar
p38251
Throttle body cleaning. Run some seafoam.
Old May 13, 2014 | 03:31 AM
Jim W.'s Avatar
Jim W.
Thanks. I will pick some up tomorrow. i would guess it should be added to a full tank of gas.
Old May 13, 2014 | 08:39 AM
Izero's Avatar
Izero
http://www.obd-codes.com/p0410
Old May 13, 2014 | 02:33 PM
Jim W.'s Avatar
Jim W.
Thanks, at this time the cel is off. When it comes back on i will check to see for sure it is a p410. The imtermittent light is weird. It can go for a month at not show, then only last for a few days.
Old May 13, 2014 | 04:37 PM
Izero's Avatar
Izero
FYI codes are usually A letter and 4 digits... so we're all assuming you're talking about P0410 right now...
Old May 14, 2014 | 01:18 AM
Jim W.'s Avatar
Jim W.
Yep P0410.
A question about using Sea Foam. Will it hurt to use the spray type Sea Foam in the throttle body while it's running? I do plan on adding it to the fuel tank.
Thanks, in advance.
Old May 14, 2014 | 09:54 AM
Izero's Avatar
Izero
My best advice is to use it as it directs you to on the can itself...
The bottle of liquid (non-spray) generally works better, but it's your truck and your call.
