Gas tank HELP
Old May 24, 2014 | 06:57 PM
starship's Avatar
starship
Default Gas tank HELP
I need a bit of help with a 26gl gas tank on my 2006 Ram are some parts that cant be replaced on the tank or will have to buy a new tank thanks
Old May 24, 2014 | 10:01 PM
What happened to the tank?
Welcome to DF!
In all reality, your truck is new enough, just about everything on it should still be available.
Old May 25, 2014 | 08:50 AM
Welcome to DF. Moving to the correct section.
Old May 25, 2014 | 09:27 AM
starship's Avatar
starship
Its the front rollover valve that i cant find it. has a crack on top of it dodge said i have to buy a new tank....the valve is molded in the tank
Old May 25, 2014 | 09:51 AM
tantofolder's Avatar
tantofolder
While I can't say for sure,I will say that the dealerships often try to sell you an entire unit even if you only need a certain part.For example,if you break a retaining clip on a taillight they will try to sell you the entire light.I would try searching online for that particular part( be sure to cross reference part #).Someone else here may have more detailed info for you on that particular part or a source to obtain it.Good luck!
Old May 25, 2014 | 10:00 AM
RDuck's Avatar
RDuck
Deleted.
Old May 26, 2014 | 09:27 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You will not find individual parts available and for sale other than the tank and pump.
