Stereo quit,keyless remote not working....
Old Jun 14, 2014 | 02:19 PM
twcbones's Avatar
twcbones
Default Stereo quit,keyless remote not working....
I have a 2004 1500 Ram. The stereo has stopped working and the display is out = no clock. The keyless door remote does not work unless the key "on". The door lock swithes only work when the key is "on". Once the key is off, the security light in the dash comes on ,but the light is weak...it lights up about 50% and it has a light buzzing sound....it doesn't stop unless the key is "on" All these issues started at the same time. All my equipment is factory equipment (sound system,remote entry) since it was new. Does anyone have any experience in correcting these kinds of issues?
Thanks
Old Jun 14, 2014 | 07:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sounds like a bad wire, connection, fuse somewhere.
You can download a free copy of the service manual from the links below in my signature and use the electrical section to find fuses, follow wires/circuits, ect
Old Jun 15, 2014 | 07:26 AM
thunderhawk09's Avatar
thunderhawk09
It Sounds like contacts in Ignition Switch broke Or Burnt up All Of the Items Listed Runs Through The Ignition Switch I Would Check It Because The Remote is Disabled when Operating correctly when switch is on so that right there tells me something is not right in that switch
Old Jun 15, 2014 | 12:02 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
+1
I would indeed take the column shrouds off and look at the ignition connector and switch terminals.
