2004 hemi pcm replacement
Old Jun 14, 2014 | 06:39 PM
fj5gtx's Avatar
fj5gtx
Default 2004 hemi pcm replacement
I had a problem with a persistent p0058. Sensor and wiring checked out. So I bought the same part # pcm, used from ebay. Arrived today, pulled the battery positive cable, and changed it out.
Good news, check engine light is no more. Starts up fine, then dies as soon as it drops to low idle. No codes, just won't run at idle. Do I have a bad replacement pcm, or is there something I need to do to initialize it ?
Runs fine with the original computer, but the CEL is keeping me from getting an emissions inspection
Old Jun 14, 2014 | 06:44 PM
p38251's Avatar
p38251
May need to be re flashed.
Old Jun 14, 2014 | 07:41 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
PCMs are VIN programmed and if there is a mismatch, you will get a code. However, I'm not sure it will be a DTC code.
What is the current code you have now? If it is the same, then the PCM likely isn't your problem.
Old Jun 14, 2014 | 08:02 PM
fj5gtx's Avatar
fj5gtx
Maybe my first post wasn't clear.... the original pcm was giving me p0058. I checked the wiring and sensors, all ok... nothing left but the pcm.
The replacement pcm doesn't give me a code.... but it dies as soon as it tried to drop to idle. I don't know what to expect when I just drop a replacement pcm in the truck, should it run?
I expected to have to flash it for inspection. and have a dealer appt scheduled for Wednesday to flash a replacement. Don't really want to pay the dealer to flash a broken one !
Old Jun 14, 2014 | 08:04 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You should have bought one from www.solopcms.com where they will sell it at a good price and pre-flashed / VIN matched
Old Jun 14, 2014 | 09:43 PM
fj5gtx's Avatar
fj5gtx
Yeah, I could go that way.
But would really like to know if its normal to swap a computer and have it not idle. If its normal, pcm cost plus flashing cost of this one will save me $110 over the solpcms option. I guess I can call the Dealer on Monday and see what they say.
Old Jun 15, 2014 | 12:24 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Is it normal? Likely not. It should run fine regardless.
Old Jun 17, 2014 | 11:17 PM
T-Muns's Avatar
T-Muns
My truck has seen 4 different PCMs, all from junkyards and they ran fine. My truck doesn't have the security system (I think it's called SKIM) so I always made sure my new pcms didn't have it either.
You might want to look into that.
Old Jun 18, 2014 | 07:22 PM
fj5gtx's Avatar
fj5gtx
Thanks for the info!
Ebay seller sent me another... just arrived today and I installed an hour ago. Runs fine on this pcm, and no pesky p0058 code anymore.
Only thing, the A/C indicator lamp won't light up.. and the heater mirror indicator is flashing. I read on a forum that if the recirc door is broken, that happens. Mine is removed, I have the replacement but haven't got around to put it in. Perhaps its time to put that door in.
Do I need to have the dealer flash this computer? Its exactly the same number 56029-116AF, which I assume corresponds to the program they put on this thing. My odometer is showing correct mileage, I had assumed it wouldn't because the refurb guys seem to want your mileage... maybe that is for warranty?
Old Jun 18, 2014 | 07:40 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
No sir
