Pinion leak; what the heck is Drive shaft balancing fluid??
Old 06-28-2014, 07:18 AM
RDuck's Avatar
RDuck
RDuck is offline
Our driveline guy laughed pretty good about it.
We did discuss the probability of it working. Problem is how to keep the fluid inside the shaft when it flat on the balance machine and not have it run out or boil when the yokes are being welded on.
They are welded on the balance machine to also check for being true straight.
Also, driveshafts are never truly horizontal so all the fluid would be at one end. Except under acceleration or deceleration. As you can imagine.
It would never truly work. Good in concept.
And it would all leak out if you got a hole in the shaft and the fluid is extremely harmful to the environment.
Lol.
Old 06-28-2014, 01:40 PM
pizza442's Avatar
pizza442
pizza442 is offline
Originally Posted by gcburkett
I picked a drive line shop for the rebuild but the dealership can so a differential seals for not much more than independent shops. They should have experience since there has been a pinion nut recall recently.
What, there's a recall out there?
Old 06-28-2014, 02:43 PM
gcburkett's Avatar
gcburkett
gcburkett is offline
Yes, it does not affect your year, but most dealership should have experience dealing with the differential or at least checking the torque on the pinion nut. The service manual procedure for replacing the pinion seal calls for measuring the rotational torque before you remove the pinion nut. I think many individuals plus probably a lot of mechanics will short cut this by removing the nut and trying to return the nut the same number of turns.
http://www.ramtrucks.com/webselfservice/pdf/N08.pdf
Old 06-28-2014, 06:35 PM
pizza442's Avatar
pizza442
pizza442 is offline
Does the serv. manual show how to replace just the seal and not the whole pinion bearing assembly? If so, the dealer might be willing to just the min. needed and not an $800 ordeal
Quick Reply: Pinion leak; what the heck is Drive shaft balancing fluid??
