Different Fuel Pump Diesel / Gas
Old Jul 5, 2014 | 05:15 AM
Rik's Avatar
Rik
Default Different Fuel Pump Diesel / Gas
Hi!
Where is the different in the fuel pumps for Diesel and Gas? Or fits a fuelpump from a diesel in my "Gas-Ram"?
Thanks!!
greetings
Rik
Old Jul 5, 2014 | 05:24 AM
RDuck's Avatar
RDuck
Diesel is way higher pressure.
Won't work in a gas truck.
A gas pump will work in your Ram.
But, I may be off. Maybe the gas pump supplies a higher pressure pump for diesel and the in tank pumps are the same in your specific unknown year of Ram.
Old Jul 5, 2014 | 05:25 AM
RDuck's Avatar
RDuck
Rereading this. Why do you want a diesel pump in your gas truck anyways? Very curious.
Old Jul 5, 2014 | 05:28 AM
Rik's Avatar
Rik
thanks for your answers!
my RAM is a 5.7HEMI from 2003/04.
Its possible that the sender unit from the fuel pump is out of order and now i can get a new fuel pump for a diesel for very small money
that is the reason why i ask...
Old Jul 5, 2014 | 05:39 AM
RDuck's Avatar
RDuck
Ahh. Hope someone can honestly say it will work for you.
I dont think your going to be lucky with that though.
Old Jul 5, 2014 | 10:00 AM
dirtydog's Avatar
dirtydog
Moderate User
I'm not sure about design fitment, but the seals and o-rings are a different compound for gasoline to resist deterioration.
Old Jul 7, 2014 | 11:43 AM
Izero's Avatar
Izero
The Diesel pump WILL NOT work for your Truck... They are completely different... and even operate differently.
Buy the right part!
Old Jul 7, 2014 | 05:28 PM
Gone Fishin's Avatar
Gone Fishin
Yup, if you look up the numbers for the gas pump, or the diesel lift pump, they are different, the diesel has a second high pressure pump on the engine for the injectors
Old Jul 9, 2014 | 04:44 PM
dodgetrucker75's Avatar
dodgetrucker75
long story short, NO the diesel in tank pump will not work in the gas truck
just to clear up the info...the in tank pump for the diesel is actually much lower psi than the gas pump, the diesel pump is roughly 15 psi, the gas pump is about 60 psi,
the seals and lines are all compatable, (i have two converted trucks) and actually use a gas in tank pump for one of them, hope this helps
