Overheating when towing!
Old Jul 18, 2014 | 02:48 PM
cd36c's Avatar
cd36c
Ya, where is your fan sensing temperature to turn on/off, and what temp is it set at? What is the CFM of the fan you used? Do you know your fan was definately coming on while you were towing? You could hook up a small LED on the switched side of the relay to see when it is trying to turn it on and off.
Old Jul 18, 2014 | 08:38 PM
MikeHTally's Avatar
MikeHTally
Originally Posted by Arctodus
I was thinking that as well, the e-fan just not keeping up with the motor. Can I run the mechanical inline with the e-fan? Also why replace the t-stat, you think that the new one is not working properly?
You can run both, but why? My e-fan keeps mine right at the 1/2 mark pulling a trailer in city traffic. Also kept it right on the mark 45 minutes waiting for a tow-truck for my daughter's Camry.
All this sounds like your 'stat is stuck open.
Old Jul 18, 2014 | 10:39 PM
Arctodus's Avatar
Arctodus
All good questions, my e-fan is set to come on at 180* or when I turn on my A/C, my tranny fluid is brand new as I just had a tranny service done. My sensing unit is pushed through my radiator right where the upper hose meets the unit as was instructed by Black Magic.
Old Jul 18, 2014 | 10:41 PM
Arctodus's Avatar
Arctodus
I know the fan is definitely on, when I am parked the heat temp drops to almost 1/4.
Old Jul 19, 2014 | 08:30 AM
MikeHTally's Avatar
MikeHTally
"... or when I turn on my A/C ...". That isn't necessary - the A/C condenser has its own fan.
Old Jul 20, 2014 | 01:39 PM
Arctodus's Avatar
Arctodus
Don't know if it is necessary or not but that what the Black Magic instructions suggested to do.
Old Jul 20, 2014 | 01:44 PM
Arctodus's Avatar
Arctodus
Originally Posted by dirtydog
Couple of questions...
What do you have for a temp control unit? location?
Do you have the entire shroud sealed off to the fan or is the fan just dropped in place with gaping holes all around? The outer perimeter really needs to be sealed so the fan can pull air across all fins of the radiator.
Honestly, fo me, the stocker does the job and I wasn't risking my Lifetime warranty for the hassle of an electric fan assembly. The only bonus with the electric fan are the few hp gained at the crank...
lastly, how's your transmission fluid?
Dog, I removed the shroud as the Black Magic instructions told me to do. The fan is sealed off against the radiator. The tranny fluid is brand new, I had the gear shop do a tranny service when they did my gears.
Old Jul 21, 2014 | 05:48 PM
MikeHTally's Avatar
MikeHTally
Only if there is no separate condenser, where the A/C dumps heat into the cooling system. The Ram has separate A/C cooling.
Old Jul 21, 2014 | 07:25 PM
RamRod37's Avatar
RamRod37
Hi ya'll,
So I recently changed jobs and got a nice little bonus which I decided to put into my hobbies for once. Starting with a nice gun safe, a couple of new guns and most of all my Ram. Since day 1 it has always been a little sluggish due to it's size and weight being a Mega Cab with a Hemi. So besides some cosmetics ( nFB nerf bars, custom fitted floor mats, dash cover etc ) I installed a Wicked flow exhaust true dual in/out cutting out the restrictive y-pipe, Black Magic e-fan, new 160 amp alternator to keep up with the fan, 180* t-stat and all new HOAT coolant, new serpentine, new spark plugs( regular copper ones )a tranny tune-up, Superchips programmer and best of all, 4.56 gears w/ a Mag-Tech cover.
Now I'm running alot cooler, my temp needle used to run in the middle of the gauge and now runs at a 1/4. I came on vacation with my family, hooked up to my boat and the needle immediately started rising, I barely got to the house when my needle was at 3/4. It is a 4 hour drive to my vacation house in Lake Havasu, AZ which is about 115* outside, but the truck ran like a champ all the way here. I went to O'reilly's yesterday and bought a new radiator cap (16#) and it helped a little but the needle still goes over 1/2 and the house is only a couple miles from the lake. Without starting to replace the whole cooling system I thought I would ask for help since this forum is usaully pretty good with their ideas. Any and all help would be very much appreciated and thank you in advance for your time.
Well Sorry Right off the bat If Qoute Something Someone Has Already Said In A Post In Here I Didn't Read All Of Them But Anyway to my Point A Few Years Ago I Had A 92 Ford Thunderbird With The 5.0 HO And I Wanted to start Doing Locksmithing And Instead Of A Van To Work Out Of I Bought A New 6x12 Enclosed trailer And Set It Up As A Mobile Shop/Office It Was Great With Generator And All I Had Power Where Ever The Job Was Anyway Trailer Fully Rigged Weight was 2700 LBS Now I Pulled This Trailer With My T BIRD and It Done A Great Job but it had started running hot just when towing trailer Found out The Radiator Was Clogged I Took It Off And Took It To A Radiator Shop And Had It Rodded Out After That It Done Great Temp Never Got Above Halfway which was the norm temp for it that may be your case as well
Old Jul 28, 2014 | 04:30 PM
RacerHog's Avatar
RacerHog
Put the H.D. fan blade on with a now H.D. fan Clutch...Put the rite thermostat back in it so all the sensors work rite.... That should fix it...
