Whining noise
Old Jul 22, 2014 | 08:18 AM
cd36c's Avatar
cd36c
If it is original belt at that many miles, that belt is probably shot. I don't usually have belts last that long for me.
Old Jul 22, 2014 | 10:51 AM
jacks187's Avatar
jacks187
Ok so I went out and took the belt off and started the engine, no noise. Turned the pulleys, they turn freely and when shook them, the Power steering pump pulley moved. Not moved as in wiggly and dangling but like a small click movement in and out. Not enough to throw the belt off track. The belt is in good condition but as you all said its old and could use a changing. The Fan pulley is nice and sturdy. Now i just have to figure out how to go about removing the front part of the truck like the frame, radiator and fan shroud to get to it easier.
Old Jul 22, 2014 | 12:17 PM
cd36c's Avatar
cd36c
That's overkill, go buy a belt first and see if that fixed your problem, at that age it should be replaced as preventative maintenance. If it still makes the noise with the new belt keep digging.
It could also be a defective tensioner as well. Did you check the idler pulleys, do they spin without any roughness? It doesn't take much roughness when spinning by hand to turn into a whine when spinning at 2,000+RPM.
Old Jul 22, 2014 | 08:03 PM
jacks187's Avatar
jacks187
Ok cool, one step at a time then. I already scheduled an appt with the dealership so they can use their gadgets to try and pin point it plus there was a recall for the tie rods, gettin that checked too. I say if them tie rods aint broke by now with all the cross country drivin ive done within the last 3 years, it aint gone break!!
Old Jul 28, 2014 | 09:53 PM
jacks187's Avatar
jacks187
Default Thanks Guys!!
I changed both the idler pulleys first and it still made the noise but a little fainter than it was. just changed the tension pulley about 30 mins ago and its gone but I think i can still hear it a little but I cant hear it when im driving. Its gone. Dang dealership was gone charge me 390 bucks to do a 10 min job and 80 dollars in parts!!! Rip offs!!!!
Thanks again fellas!
Old Jul 29, 2014 | 08:55 AM
djbucky3's Avatar
djbucky3
Stealership
Old Jul 29, 2014 | 11:22 AM
TejasMtnBiker's Avatar
TejasMtnBiker
patience paid off again =)
