4.7 2006 question HELP
So I've blown up my motor twice now an instead of rebuilding I'm gonna buy a new one, the question I see comanders, aspens, durangos an the rams all use the 4.7 as long as it not a flex fuel truck will any if the motors work for me or do I need a ram specific, I gotta buy this week so please help also I have 2 4.7s with blown heads one at 100k an one unknown does anyone buy these?
I hate the 4.7 I'd love to do a hemi I swap but than I need the pcm, exhaust, wire harness, fuel injectors, alternator AC pump etc just gets to pricey for me plus the motors are way more.
Also what year 4.7s should fit
If I'm not mistaken anything 03 and newer should work, just have to make sure you have the correct tooth crank tone ring. The real question is, why do they keep blowing up? Is it internal engine failure, or cooling system? Are yu using the same cooling system components that it came with?
The 1st time was a blown water pump at 90k than 6months later head gaskets i pulled the heads all 8 were destroyed. I notice one cam had a small crack an a few bad lifters, so i replaced the lifters, cam, head gaskets an head studs an decked the heads. Truck ran good temp was good, fast forward a year of no issues, truck starts running warmer than usual. I filled it(gallon low) very next day dame thing 3/4 temp gallon low coolant. At this point i realize head gasket an water is most likely dumping i to the cyclinders before i could rip into it on the 3 rd day pop. Done poof.. Im pulling the engine right now to diagnose the issue but i want to find a low mile motor or remanufactured with warranty nee water pump new oil pump an try again. Im in souther michigan if anyone has contacts on engines
