engine wont idle
Old Jul 28, 2014 | 12:10 AM
tony69's Avatar
tony69
Default engine wont idle
Hello I have a 2003 dodge ram 1500 with 5.7 engine. I was driving and the engine started to run rough. the engine idles rough and i have no engine light and no codes. can anyone give me some info on this problem. thxs
Old Jul 28, 2014 | 08:19 AM
HemiLonestar's Avatar
HemiLonestar
How old are your plugs and when's the last time (if ever) the TB was cleaned?
Old Jul 28, 2014 | 11:10 AM
tony69's Avatar
tony69
the plugs platinum and have about 70000 and throttle body about the same time as plugs. Ok I just checked the truck and yes I have a code now P0300 multiple cylinder misfire.
Old Jul 28, 2014 | 11:30 AM
abarmby's Avatar
abarmby
Those plugs are ripe.
They Need changing, along with air filter and TB clean.
Plus your PCV ontop of your intake underneath the hemi hat on left side of engine as you look at it from the front.
Do those with a cold PCM reset and see then what happens.
If still running rough, with your manufacture build year, you may need to pop the valve covers and inspect for the common snapped valve spring issues, known on 03's.
Al.
Old Jul 28, 2014 | 11:37 AM
tony69's Avatar
tony69
i just checked and it does have a code, P0300 multiple cylinder misfire. Could it be plugs or coil packs?
Old Jul 29, 2014 | 01:59 AM
abarmby's Avatar
abarmby
At 70K miles....those plugs are where I'd start.
Al.
Old Jul 29, 2014 | 11:36 AM
TejasMtnBiker's Avatar
TejasMtnBiker
you can test coil pack with ohm meter on the connections, not the coil plug side.. 6.8-8k they are good shape still... I just went thru this on mine and had 1 spring bad but replaced all I ordered from Art... crane tool is the way to go works like a champ no need to remove the booster or rad & fan assembly just lay on top
Old Jul 29, 2014 | 06:29 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Keywords 2003 - 5.7 - won't idle
What rings in my head is broken valve spring(s)
Maybe. Maybe not. Might be worth pulling the valve covers and checking.
Old Jul 29, 2014 | 11:20 PM
tony69's Avatar
tony69
Ok guy's thanks for the replies and help. I just checked the plugs which are support to be good for 100000 miles platinum plugs and not. I had six plugs with .55 to .65 gap and checked coils and have .8 on all coils. this should take care of the issue. Thank you all for the support. Wish you all the best
thax
Tony
Old Jul 30, 2014 | 02:40 AM
thzpcs's Avatar
thzpcs
Yeah... Plugs really aren't supposed to last 70k, regardless of what they say. Sounds like it might have killed the coil packs too.
