Do fender flares cause rust?
Old Aug 30, 2014 | 07:29 PM
JOHNSN10's Avatar
JOHNSN10
Default Do fender flares cause rust?
My 05 ram has NO rust anywhere and i want to keep it that way,lol. I bought new pocket style fender flares and they came with plastic pop through screws as well as self tapping screws. I dont want to cause rust to start so how do i prep the holes after i drill them so rust wont start? Should i drill holes then buy new plastic pop through screws so that i dont have to use self tapping screws? Do i need to use touch up paint on the metal after drilling holes? Also do flares need to be taken off every 6 months or so to clean out from behind them and prevent rust?
Old Aug 30, 2014 | 09:25 PM
thzpcs's Avatar
thzpcs
Unfortunately by drilling into the metal, you're removing the protective coat on the metal, and it will eventually rust unless it's recoated. It's probably a good idea to do a combo of touchup paint and the pop screws to keep yourself protected.
Old Aug 31, 2014 | 07:36 PM
dirtydog's Avatar
dirtydog
Moderate User
You can return them and get the double sided stick one's like factory. Maybe not as hot, but still allows that extra room for tire width.
That brings me to my next question....Do you have wider tires than stock? If not, then those pocket style flares will dwarf your tires and look a bit funny.
Old Aug 31, 2014 | 07:49 PM
HammerZ71's Avatar
HammerZ71
Seal it with some clear nail polish and you won't have an issue with rust. Now where the flares rub the paint off over time on the outside of your truck is another story...
Old Sep 2, 2014 | 10:43 PM
rob2129us's Avatar
rob2129us
Default rust
I live in ny and every dodge 08 an older here either has rust or has been repaired. I wash my 07 thoroughly inside and out underneath everywhere and it has the typical dodge rust. Anyone know do they make a replacement panel for the wheel wells. If not it would be a good money maker.
Old Sep 4, 2014 | 08:12 PM
fj5gtx's Avatar
fj5gtx
replacement panels...yes, multiple suppliers... from a patch to an entire replacement panel. Having someone do the work for you, would make you want to find a southern bed to swap out!
Old Sep 5, 2014 | 08:46 AM
Izero's Avatar
Izero
you'll have to drill and paint the inside of the hole where any paint has been removed... then you can insert the popclips in there and install the fenders flares like normal.
