Ram 2014 coil springs must read!...
Old Sep 9, 2014 | 08:12 PM
RamRvca's Avatar
RamRvca
Default Ram 2014 coil springs must read!...
Working on a project 1500 08 Ram doing some suspension work needing to find out if anyone has any knowledge if 2014 Ram front coils put into a 1500 08 how much advanced would the lift be? and does it need the shocks from a 2014 ram in order to use the coils or will the 08 stock shocks be ok to use with 14 ram front coils.
need somebody with an expert of suspension work day in and day out..
Old Sep 13, 2014 | 03:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you want to lift the truck, do it right and get a full suspension lift that has crossmember drops and lift spindles. This way not only is it not a stiff ride but also makes alignment possible and easy.
