Oil leak..but from where?
Abbreviated story:
2003 5.7 4x4. Replaced motor, runs great except it was leaking oil from the bell housing area pretty bad. As it turns out I had forgotten to apply black RTV to the 4 points required. Today I took the pan off, new gasket assembly, black RTV and back together it went. Well... same thing.. if idling it drips a tablespoon or more every 5 minutes so it is significant.
I looked all over, my best guess is that it is coming out of the dipstick tube insertion point somehow and running over the side of the block and down to the rear of the oil pan? I have the inspection plate off, and if it was the rear main it would be pretty obvious right? There is no oil slung all over the TC.
There are a few pictures to help anyone who may be able to give some advice, the area in red is where the oil seems to be traveling along. Any and all assistance very appreciated. Thanks.
Ok, so update time:
I checked that the oil was not coming from the front main. Then I added UV Dye and let it run for 15 minutes (and inspected while running). All of the uv dye appears to be coming out on the drivers side of the motor with the majority of it appearing in the red circled area (hard to see the uv on my phone pics sorry). I verified that the oil is also not coming from the dip stick tube above the oil pan.
If this was the rear main wouldn't it be coming out of the bottom of the bell-housing and getting everywhere (TC etc)? From what I see either I didn't add enough black RTV to the rear main t junction or it is leaking from the seal between the block and the rear main assembly (one piece on the 5.7)? The 2nd pic shows some more oil pooling at the front of the motor (still drivers side).
So the bad news. I checked again with the UV light and got into a position where I could see into the bellhousing better. Rear main is leaking, I did the oil pan anyhow just to make sure and the leak is the same.
So, being as we just put this motor together I know the rear main cannot be changed without separating the motor from the transmission. Easier to pull motor again or pull the trans back? If pulling trans, is it just disconnect both drive shafts, any electrical connectors, TC selector and unbolt and move back? Any tips on that process are appreciated.
